TwinTurbo.NET: Nissan 300ZX forum - Something in the timing belt replace. Perhaps you >>
Subject Something in the timing belt replace. Perhaps you >>
Posted by ZUL8TR on March 11, 2010 at 8:09 AM
  This message has been viewed 101 times.
In Reply To Weak power and delayed throttle posted by TRdave on March 11, 2010 at 08:02 AM
Message missed a tooth or 2? First check the static timing at the crank with a light, should be 15 BTDC. One check on if you put all back together correctly is that the static timing will be the same as before the work was done provided you know the before timing?
You say did or attempted to do. Which ones in the list did you not do but attempted?
ZUL8TR in Orlando,FL
